Sprints 2025 - timetable and projects selected
Marathon and Sprint information for the 2025 season
UBT - Timbo
Site Admin
Contact:
Re: Sprints 2025 - timetable and projects selected
Post by UBT - Timbo »
Yeti wrote: Fri May 30, 2025 12:30 pm NekdDrgn
Did you explicitly allow stat-Export at the Projekt?
Hi Yeti
YES !! Excellent comment !
Hopefully NekdDragn will check this out !
NekdDrgn
Registered FB member from 2025
Post by NekdDrgn »
A little checkbox got me! Thanks for the help!
UBT - Timbo
Site Admin
Contact:
NekdDrgn wrote: Fri May 30, 2025 3:43 pm A little checkbox got me! Thanks for the help!
HI
Excellent !
This acts as a good reminder to me to ensure that all Members "tick the box" to ensure that their stats are exported !
Spot T
Post by Spot T »
Cruncher Pete's telemetry seems to have an issue
UBT - Timbo
Site Admin
Contact:
Spot T wrote: Sat May 31, 2025 8:03 pm Cruncher Pete's telemetry seems to have an issue
Hi
I assume you mean Cruncher Pete's stats? But in which area? The Marathon? Any of the Sprints?
So, some context/explanation would be a BIG help.
As for the current NumberFields stats, the last FB update took place at: 2025-05-31 17:11:12 UTC
So, I have tried to update them, using the limited tools I have on the FB website, but it is not updating :-(
And looking at BOINCstats, their latest stats update (at time of writing) is given as:
https://www.boincstats.com/stats/122/project/detail/
Last update user XML 2025-05-31 16:11:12 UTC (07:30:37 old)
Last update host XML 2025-05-30 16:11:15 UTC (1 day 07:30:34 old)
Last update team XML 2025-05-31 16:11:12 UTC (07:30:37 old)
So, maybe it is a NumberFields issue?
Spot T
Post by Spot T »
Hi Tim
yes I was referring to the current sprint stats but I don't have a screenshot to post. Last night, around 08.00 pm, the L2 user leaderboard was pretty weird, Cruncher Pete appeared about twenty times and with over 3 million credits in each one.
The term "telemetry" was ironically referring to the data transmitted by f1 cars, let's say... a team radio :D .
Regards
Spot T
Yeti
Post by Yeti »
UBT - Timbo wrote: Sun Jun 01, 2025 1:14 pm As for the current NumberFields stats, the last FB update took place at: 2025-05-31 17:11:12 UTC
HM, I don't see this:
For me, the current Sprint (Numberfield) shows all Data as it should:
Screenshot 2025-06-01 195132.png (27.49 KiB) Viewed 10020 times
UBT - Timbo
Site Admin
Contact:
Spot T wrote: Sun Jun 01, 2025 3:47 pm Hi Tim
Regards
Spot T
Hi
OK - that helps me a lot...for which many thanks.
My guess is that all the League tables were updating, based on whichever files (from many BOINC projects) were being accessed and somehow, there was a "glitch". What doesn't help is that "Cruncher Pete" has multiple BOINC accounts, some of which are on projects that are closed (and hence any data like CPID or email address cannot be updated if their websites are non-operational).
https://www.boincstats.com/stats/search ... ncher+Pete
So, it is possible that some things were not being tabulated correctly during the "back office" computations?
If you see this anomaly happen again, please try to get a screen shot and I can get Sebastien to look into it.
Spot T wrote: Sun Jun 01, 2025 3:47 pm The term "telemetry" was ironically referring to the data transmitted by f1 cars, let's say... a team radio :D .
Yes, I did get your meaning...but sometimes, I have to ask for clarification as I do not know the nationality of most members, so it is better to ask for more information, to ensure I understand their exact meaning (as sometimes translated words might have multiple meanings !).
UBT - Timbo
Site Admin
Contact:
Yeti wrote: Sun Jun 01, 2025 6:52 pm HM, I don't see this:
Hi
Thanks for the feedback.
The FB admin pages shows the last update was as follows:
Last contact : 2025-06-01 19:11:20 UTC
Last update : 2025-06-01 17:11:14 UTC
But I'm writing this 4+ hours after the Sprint ended, so there could have been other updates that took place earlier today.
The FB stats League tables now visible do appear to be correctly formatted so, hopefully, all should be well.
UBT - wbiz
Post by UBT - wbiz »
The first time I saw it, Cruncher Pete had a load of entries at the bottom of the table, later on it changed to positions at the top of the table.
