The Link is Broken  >*MOD_PYTHON ERROR<
https://formula-boinc.org/admin/team_registration.py
Sane for the Team Link.
MOD_PYTHON ERROR
ProcessId:      7968
Interpreter:    'formula-boinc.org'
ServerName:     'formula-boinc.org'
DocumentRoot:   '/web/sebastien/Formula_Boinc'
URI:            '/admin/team_registration.py'
Directory:      '/web/sebastien/Formula_Boinc/'
Filename:       '/web/sebastien/Formula_Boinc/admin/team_registration.py'
PathInfo:       ''
Phase:          'PythonHandler'
Handler:        'mod_python.publisher'
Traceback (most recent call last):
  File "/usr/lib/python2.7/dist-packages/mod_python/importer.py", line 1537, in HandlerDispatch
    default=default_handler, arg=req, silent=hlist.silent)
  File "/usr/lib/python2.7/dist-packages/mod_python/importer.py", line 1229, in _process_target
    result = _execute_target(config, req, object, arg)
  File "/usr/lib/python2.7/dist-packages/mod_python/importer.py", line 1128, in _execute_target
    result = object(arg)
  File "/usr/lib/python2.7/dist-packages/mod_python/publisher.py", line 213, in handler
    published = publish_object(req, object)
  File "/usr/lib/python2.7/dist-packages/mod_python/publisher.py", line 425, in publish_object
    return publish_object(req,util.apply_fs_data(object, req.form, req=req))
  File "/usr/lib/python2.7/dist-packages/mod_python/util.py", line 554, in apply_fs_data
    return object(**args)
  File "/web/sebastien/Formula_Boinc/admin/team_registration.py", line 76, in index
    cur2.execute('SELECT nom FROM equipes_fb_2023 order by nom')
  File "/usr/lib/python2.7/dist-packages/MySQLdb/cursors.py", line 250, in execute
    self.errorhandler(self, exc, value)
  File "/usr/lib/python2.7/dist-packages/MySQLdb/connections.py", line 50, in defaulterrorhandler
    raise errorvalue
ProgrammingError: (1146, "Table 'stats_equipes.equipes_fb_2023' doesn't exist")
MODULE CACHE DETAILS
Accessed:       Sun Jan  1 03:55:03 2023
Generation:     1
_mp_5191f52d9f6ef15e8e8574cb2b90e43e {
  FileName:     '/web/sebastien/Formula_Boinc/admin/team_registration.py'
  Instance:     1 [IMPORT]
  Generation:   2
  Modified:     Sun Dec  4 10:29:02 2022
  Imported:     Sun Jan  1 03:55:03 2023
							User Registration for 2023 is now OPEN (Link is Broken)
Crunching@EVGA The Number One Team in the BOINC Community. Folding@EVGA The Number One Team in the Folding@Home Community.
