View for Sprints in older Years
Forum issues, bug reports and suggestions
marodeur6
Post by marodeur6 »
Hi,
I have tried to have a view on the results of the sprints in 2021.
Every sprint shows:
Code: Select all
MOD_PYTHON ERROR
ProcessId:      15421
Interpreter:    'formula-boinc.org'
ServerName:     'formula-boinc.org'
DocumentRoot:   '/web/sebastien/Formula_Boinc'
URI:            '/sprint.py'
Directory:      '/web/sebastien/Formula_Boinc/'
Filename:       '/web/sebastien/Formula_Boinc/sprint.py'
PathInfo:       ''
Phase:          'PythonHandler'
Handler:        'mod_python.publisher'
Traceback (most recent call last):
  File "/usr/lib/python2.7/dist-packages/mod_python/importer.py", line 1537, in HandlerDispatch
    default=default_handler, arg=req, silent=hlist.silent)
  File "/usr/lib/python2.7/dist-packages/mod_python/importer.py", line 1229, in _process_target
    result = _execute_target(config, req, object, arg)
  File "/usr/lib/python2.7/dist-packages/mod_python/importer.py", line 1128, in _execute_target
    result = object(arg)
  File "/usr/lib/python2.7/dist-packages/mod_python/publisher.py", line 213, in handler
    published = publish_object(req, object)
  File "/usr/lib/python2.7/dist-packages/mod_python/publisher.py", line 425, in publish_object
    return publish_object(req,util.apply_fs_data(object, req.form, req=req))
  File "/usr/lib/python2.7/dist-packages/mod_python/util.py", line 554, in apply_fs_data
    return object(**args)
  File "/web/sebastien/Formula_Boinc/sprint.py", line 368, in index
    if ligne[4]!='':
IndexError: tuple index out of range
MODULE CACHE DETAILS
Accessed:       Tue Feb  1 14:30:33 2022
Generation:     3
_mp_5f8176bc689a4865fce6172383a87dad {
  FileName:     '/web/sebastien/Formula_Boinc/sprint.py'
  Instance:     1 [IMPORT]
  Generation:   4
  Modified:     Thu Dec 30 17:57:32 2021
  Imported:     Tue Feb  1 14:30:33 2022
For years before it is the same.
Is it possible to fix this?
Regards Jörg
